My mb won't post after changing psu
Mohammadjaber
Hi
I have changed my dead psu with a new one  i plugged the 24 the cpu power the sata to the ssd and hdd and al the reaming power blugs i powerd on everything worked fine but the system won't post
The monitor stys black the whole time
Please help
no post codes, no debug lights no nothing? you should get something as your system is indeed powering on
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
Maybe that power supply took with it other components like the motherboard and the CPU.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
The debug light is off
When i power on it goes white then green then off
7 minutes ago, Chris Fortune said:
What is the power cable that is in front of the system?
An extra pcie cable
from what i can gather, white is a GPU problem and green is a boot drive problem. try to clear cmos and replugging in the GPU and drives
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
I thought of that but I'd not know how to tell if my mb is dead
Tried both the coms i toke the battery out leave it for 2 min and i put it back
I would be surprised with the amount of activity you are getting but not impossible, looks more like a GPU issue to me. Can you list system specs?
Usually when power supplies die they kill other components in the system.
It could be that the CPU is dead and the motherboard is OK,but if you try a healthy CPU in a damaged motherboard it can kill the CPU so it's a tricky situation.
If it's an Intel platform it probably has an iGPU so it's easy to test that.
Usually when power supplies kill components the RAM and GPU survive.
Not used intel since the original Pentiums, more familiar with the AMD idiosyncrasies. A hardware list might be helpful to be more specific with suggestions
Core i7-7700
Gtx 1070ti
Can you post a pic of the system that shows all the components?
Just had a nasty thought, is it possible the monitor died at the same time either as a knock on or coincidence?
The system has an iGPU.
But if it is disabled in BIOS it would be useless
That's a big if,It's usually enabled when there is no GPU installed.
True, not sure how you would test it either.
