One of my case fans is not working, not sure why
Solved by Letgomyleghoe,
Just now, slickdick said:lmao.. yea i just spun it and it began working.. i just got this case with the fans brand new. so i should buy a new fan then?
see if you have any further issues, if you do, contact the case manufacturer or reseller for a new fan.
