Near silent fans?
kewtz
My next build will reuse my Fractal Design R4.
For CPU cooling I’m looking at the Scythe Fuma 2 (for the 5900x) - but I’d also like to replace my case fans.
For 120/140mm fans, what fans offer quiet performance for moving air in higher end builds but are relatively quiet?
My front fans are intake, top exhaust, rear exhaust.
I currently have the AMD FX-6300 in the case so I rarely see temperature issues now.
The 5900x is substantially more powerful so I want to do what I can to keep it chill.
Potato Revamp
CPU: AMD 5900x || GPU: nVidia RTX 3080 || RAM: 32gb Trident Z Neo CL16 || Case: Fractal Torrent Compact || CPU Cooler: Scythe Fuma 2 || PSU: Corsair RM850 Gold || Storage: ADATA SX8200 Pro (1TB), 2x Samsung Evo 870 (2TB)
Quietest and best performance is Noctua NF-F12 or the NF-A14
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
NF-A12x25, if all you care about is the best performance at as low a noise level as possible.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
I've got an R4 too. I'm running 3 in 2 out, with no top fans. 2x 120x38s in the front running @ 7v, 1x TY-147B on the floor as intake, 1 120x38 @ 12v in the rear as exhaust, and 1x 92x38 @ 5v between the PSU and GPU exhausting. Its pretty quiet and moves a ton of air. Definitely stronger than Noctua fans, but its not silent.
AMD R7 5800X3D | Thermalright Frost Commander 140, TY-143
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
Noctua are the best!
Everyone likes Noctua :D
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
Cool, thanks. R4 isn’t a bad case, probably not the best these days for thermals but we shall see!
Backup case is a Meshify C.
Potato Revamp
I have a Meshify C as well, and in that case I use 6x 120x38s lol.. I have the room using z77. It’s way overkill but awesome. R4 is ok but not nearly as good, even if you have strong fans. I can’t use my Meshify with my current mobo, but with my Asus I could.. but it’s dead now. With my X58 I could only run 5.
I am building a Z490 system now starting with a 10600K. Should be up and running in a month. So I hope those fans will fit as I am hoping to run above 5GHz 👌🏻
There aren't any silent fans, you can only try to have them running at low rpm, as high rpm is what makes them noisy.
Thats not to say there aren't some fans that produce lower noise than others...
I have 2 noctua and 2 Bequiet fans in my case, the Bequiet are more silent, but I feel the noctua push more air. I also don't really care how fast they run, think the noctua are at around 1000 rpm (or maybe 600) while idling, and when under load all 4 fans are near their max.
Also when idling both Bequiet are off (one of them is the exhaust) cause I don't need them, temps are quite low (between 30 and 45C) when idling
Case : inwin 301, all air
(got it down to 49C now, with lower gpu fan speeds too :)
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
I wish I could set fan curves like that.
No fan speed control with my current hardware.
I have a 12v, 7v and 5v fan switch on the case but nothing automatic.
Potato Revamp
How come? Is it a motherboard issue I suppose?
That kinda sucks I guess, I couldn't live without fan control, despite what I described above my pc is near silent - at least in theory, it really was when I had a msi 1060 gaming x, even while gaming, but now the evga 1070 is more noisy, the fans are pretty weak, it's ok but compared to the msi a joke, fan control on the msi was a lot better too, by default and otherwise (I always use custom fan curve tho to avoid throttling, which basically always occurs with nvidia default fan curves, they kick in much too late...)
What motherboard do you have anyway?
Make no mistakes it took me a long time to set fan curves up to my liking,  needed a couple of bios updates and also I have to use MSI control center for basically controlling *one* fan cause for some reason the header is the only one that can't be controlled properly with bios settings..
But generally when the case is closed, under light or no load I don't really hear my case fans at all, the only thing I'm hearing is the cpu stock cooler, which runs at (close to) default settings (so around 1600 while idling iirc)
-Scott Manley, 2021
Softwares used:
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Gigabyte 970A-UD3P
I just turned the switch down to 5v (honestly I forgot I had the switch, been running on 12v for 2 years now...) and it's a LOT quieter.
My raspberrypi4 fan is louder than the PC right now and idle temps are around 25-30c for CPU and 35-40c for GPU.
Potato Revamp
