LTT usually uses the iFixit Pro Tech Toolkit: https://www.ifixit.com/Store/Tools/Pro-Tech-Toolkit/IF145-307
https://linustechtips.com/topic/1270779-i-fix-it/#findComment-14224552
they are also very solid and can literally get into anything
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Canon 7D MK2 - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, GoPro hero 6 black
Dead cameras: Nikion s4000, Canon XTi
Pc's
Towers:
Main Dell optiplex 5050 "Bandog"  - intel i7-7700 - nvidia t400 4GB - 20GB ram - 1TB Samsung 990 Pro heat sink - 256GB Samsung 850 - 5TB HDD
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 16GB ram - 1TB HDD
Laptops:
main laptop "Soppo": Lenovo P14s Gen 5 - Intel ultra 5 135H - Nvidia 500 ada - 32GB ram - Samsung 990 pro 1TB
Secondary/radio programming laptop "Klukai": Dell Latitude 5430 - Intel i7 1185G7- 16GB ram - Kioxia BG6 256GB
Tertiary/Networking/radio programming laptop "Persica": Dell latitude 5414 Rugged - intel i5 6300u - 12GB RAM - Samsung 870 EVO 500GB
Any questions? pm me.
#Muricaparrotgang
https://linustechtips.com/topic/1270779-i-fix-it/#findComment-14224604
You often see the pro tech kit used in videos, but for a normal end user i love the manta driver kit. I have had it for about 2 years now and i've used about 85% of the different bits it has.
You just need to look at what you'll think you need more often and try to avoid buying extras that you'll never use. In my case i already have tweezers, spudgers, so i really only needed the massive selection of assorted bits and 63 vs 112 its not a hard choice as to which one was a better choice.
 https://www.ifixit.com/Store/Tools/Manta-Driver-Kit--112-Bit-Driver-Kit/IF145-392
https://linustechtips.com/topic/1270779-i-fix-it/#findComment-14242399
