Is there a place that will mod a case for you if you have an idea, but not the resources?
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/1270192-place-that-will-mod-for/
What@Den-Fi said regarding Protocase. Pretty much any shop that does sheet metal work can design and build whatever you want. Just be prepared for big bucks for engineering time, tooling costs, material costs and labor just to make it.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
Some metal shop in your region probably, which we don't know what is.
And yes, prepare your wallet.
F@H
GPD Win 2
Protocase does fully custom cases from scratch so not really „ modding „ but you should have at least some plan on what you want them to do
Hi
hi
It very much depends on what you want done, something simple like a PSU shroud or custom radiator mounts etc are easy but if you want a complete custom case as others have suggested places like Proto case would be your best bet or a local metal shop. Just note that stuff like that for a one off will be expensive.
