Hey all,
This is my first time posting so bare with me please. I have been watching all the gpu hype closely the last couple months. I've been seriously considering upgrading to a new gpu. I didn't know very about gpus when I built my computer a couple years ago. So at the time I got a quadro k2000. My initial intent was to us the computer for parametric modeling and some blender work for 3d printing. I've slowly moved my gaming over from console to my computer but the k2000 as you might have guessed is terrible for gaming. My monitors are 1080p res and I don't plan on upgrading those for another year or so. So here is my dilemma, should I wait and try to get an RTX 3000 series or RX 6000? Or should I just go with a cheaper option like RX 5700 or RTX 2060? I still plan on using my modeling software for "lighter" loads, but I really want to do some gaming as well. Any advice would be helpful. Thanks in advance, my build specs are below.
Gigabyte Z390
Intel Core i7-8700k (air cooled)
Patriot 4x8GB 3000mhz
Quadro k2000
Crucial 500gb sata ssd
WD Blue 1tb HDD
EVGA 550w psu
https://linustechtips.com/topic/1268324-gpu-upgrade-help/
I would get a used 20 series card. that 550w psu concerns me a little if you got any overclocks goin for you.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1268324-gpu-upgrade-help/#findComment-14205157
whats your budget?
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1268324-gpu-upgrade-help/#findComment-14205176
