Hello all,
I'm seeing some pretty high CPU temps, and am trying to isolate which component(s) need to be repaired/replaced to get back to acceptable temps.
Specs:
Ryzen 5 2600
MSI Gaming Pro Carbon X370 Motherboard (SMBIOS Ver. 2.8)
Corsair H100i AIO liquid cooler
Arctic MX4 Thermal Compound
Lian Li O11 Dynamic
6 Intake Fans and 3 Exhaust (2 of which are attached to the H100i Rad)
EVGA 2080 (Triple Slot variant)
16gb DDR4 3200mhz
No OC (but XMP is enabled for RAM)
EVGA 750 W PSU
Issue:
At desktop running only Firefox and HW Info, I'm seeing it idle at about 65C (149F).  I noticed after gaming for several hours that the rad was very hot (could feel through the top of the case; hot enough to burn bare skin).  I ran HWinfo and saw that CPU was sitting at about 104C.  I ran Prime95 to see what would happen, and it spiked to 115C, followed by a full system shutoff.
What I've Tried:
My first thought was that it's been at least a few years since I've removed the cooler, so maybe the thermal paste was past its prime (and it was the cheapest solution I could try).  I cleaned the CPU and cooler with alcohol wipes and reapplied thermal paste.  Now when I run Prime 95, I hit about 95C (better, but still high).  I've also tried pinning all the fans to 100% to see if I could get the temperature down, but no luck; even running with no panels and all fans + pump at 100% in a roughly 21C room, I'm still seeing it idle at around 65C.  My usage bounces between 4-10% at time of writing.
My Theories (In no Particular Order):
  • Maybe the lid on my processor is not making good contact with the CCX's?  I've never tried delidding or anything, but it seems possible?
  • My AIO pump is dead (I'm the second owner, I got it secondhand maybe 4-5 years ago).   Seems unlikely because it appears in CorsairLink with an RPM of 2200 or so, but I guess still possible (Would I know if my AIO was dead?)
  • My MoBo or CPU is doing something funky with voltages?  Everything is set to manufacturer defaults (except XMP for RAM), but I don't know a lot about CPU voltages, so I'm really not sure what would be (ab)normal.  Corsair Link is reporting 1.18V VCPU and HW Info is reporting 1.162 Core voltage  if that's relevant?
Things I don't Think it Is:
  • HWInfo is misreading / I should use other monitoring program - Maybe, but it did trip a thermal switch 10 seconds into Prime95, and the case was hot (burning) to the touch.  Even if the numbers aren't spot-on, they're still high.
  • Thermal Paste application - I don't go too crazy with the stuff, so I don't think it's that.  Plus, even if my initial application was bad (after using for 3+ years), reapplication should have changed things.
  • Inadequate Ventilation / Fan Orientation / Fan Types - I've got plenty, and the issues persist even when running case with no side panels.  I'm not using static pressure fans on the rad, but I've been running this config for 3 or 4 years now with previously good temps.  The only real change I've made is adding 3 filtered intakes on the bottom of my case to achieve a higher positive pressure, and the temperature problem is new.
I'd appreciate any thoughts you guys might have on how to narrow down the issue.
Minor Update:   The general consensus thus far is that my cpu pump may be dead.  I will try to get a replacement asap to determine whether that was the issue and post an update.  As the PC has been idling for the last hour or so, it has risen from 65C at desktop to now about 75C.
Resolution / Update for Future Readers:  So I installed a new 360mm AIO, and am now seeing around 25C at idle and around 40C while gaming.  The last cooler was the issue, and the fact that the pump was reporting an RPM in Corsair's software was just a red herring.  Thanks for the help everyone!
https://linustechtips.com/topic/1266861-help-narrowing-overheating-issue/
This seems very likely due to the age of the AIO over time with stress and heat.
This is one of the best hardware monitor's to pick from so the accuracy of your temperatures being incorrect are very slim.
Overall, I would say its possibly time for a new AIO or a beefy air cooler.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
This is a new issue.  Traditionally, I saw about 70C while gaming - never 100C.  As far as radiator impediments, there is a magnetic dust filter between the rad and the vents in the top of my case, but I wouldn't call that substantial.  There's no dust either (I clean the vents and filters at least once per month).
This is helpful, thanks.  If the pump is dead, should I be surprised that the H100i still reports a pump RPM of 2220?  Is this just measuring the fan that's attached to that particular header, or is this a true representation of the pump's RPM?  Similarly, when AIO pumps "die," do they become progressively more ineffective (ie, slowing down), or will it just stop functioning completely?
if you have over heating issues try disabling led lights if you have some or if your room is hot try moving the position of your pc to get some airflow and if your playing heavy games i think thats just normal but if your playing on medium or low setting it relies to much into the cpu but in high max setting it mostly relies on the gpu so just try to disable and put stuff until you get air flow
They typically stop working altogether. I think you've got a bad pump at this point as everything points to that. Do you still have your stock cooler that came with the 2600? You could try switching to that temporarily to see if your issue is solved.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
Led lights create almost no heat compared to the rest of a computer, turning them off will make almost no difference. And the temperature while gaming is dependant on the cooler not what settings you have, it is not normal to be above 100 degrees on high.
Unfortunately, I don't; I donated it to a buddy to help him build his first system.  I may pull the trigger on a cooler tomorrow.  I'll post a follow up when I can.  Thanks.
Narrowing it down: user error or inadequate or defective cooling solution.
Proposal: just use the stock cooler next time, aios etc are prone to failure, dangerous and in almost all use cases completely unnecessary.
I'm running on stock cooler, slightly lowered stock fan curve and getting ~56C while gaming...  (70-75 with the stress test thingy)
¯\_(ツ)_/¯
Edited by Mark Kaine
Forgot that I actually lowered fan curve a bit because the default was revving up way too much, unnecessarily and annoyingly
-Scott Manley, 2021
I'd recommend a cheap Bequiet or Noctua with 1 fan, everything more seems really overkill for this cpu.
-Scott Manley, 2021
Definitely sound like the aio.
I had the same issue with h100i v2
The Pump probably is not dead. The pump and cold plate are gunked up. I wouldn't be surprised if the aio is getting low on fluid too.
Its not as hard to refurb it as many makes it seem. Pretty easy tbh.
I did mine.
