Once we reach the smallest possible nm and optimized the ipc as much as we could, pushed GHz to the limit, how do we improve cpu performance besides adding more cores?
About GPU, can you add just a very large number of stream processors? Lets say you double the rtx 3080 stream processors, how far will performance scale?
https://linustechtips.com/topic/1265345-cpu-and-gpu-technology/
If we knew, we'd already be doing that. In other words, we don't know yet.
https://linustechtips.com/topic/1265345-cpu-and-gpu-technology/#findComment-14181042
Quantum computing is a thing...it's been a thing for a number of years now.
That goes beyond silicon nm sizes...
Companies like D-Wave exists.
https://www.dwavesys.com/
EDIT:
Forgot about IBM, too...and a few other big names.
https://www.zdnet.com/article/eight-leading-quantum-computing-companies-in-2020/
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1265345-cpu-and-gpu-technology/#findComment-14181044
Quantum-computing isn't a replacement for traditional computing. Quantum-computers are good at quickly finding all the possible solutions to a maths problem, but they are not good for executing logic in the way traditional computers are, so no, that's not an answer.
https://linustechtips.com/topic/1265345-cpu-and-gpu-technology/#findComment-14181051
Yes, and quantum computing is still a bit immature, it'll take a long time before we find quantum proccessors in any home.
https://linustechtips.com/topic/1265345-cpu-and-gpu-technology/#findComment-14181053
Various ways to improve performance even without a die shrink.
Look at how long Intel has dragged out 14nm :P
https://linustechtips.com/topic/1265345-cpu-and-gpu-technology/#findComment-14181054
