help HELP! Where in the UPS do I plug in my computer?
Solved by BlueChinchillaEatingDorito,
Just now, Spainz said:so then the bottom left ones?
Any of the outlets on the left that are filled in white will provide both surge protection and battery backup in case of an outage. So in the diagram you posted above, the ones labelled (8).
The ones on the right just provide surge protection like any other quality power bar, no battery backup.
