Put the CD in, when it asks where to install, click Advanced, and you can click the partitions and format from there.
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
https://linustechtips.com/topic/126512-how-to-format-hard-drive/#findComment-1682564
Boot using your Windows 8 CD, and in the installation "menu" click on Advanced settings, and you will be able to select which drive/partition you want to use. In that menu, select all your drives/partitions and click "format" (pink eraser icon) and it should wipe it. Then, reinstall the new Windows on one of these partitions, and voila, you have a fresh computer.
Note : It doesn't delete your files AFAIK, it just deletes the reference to them. This means that they still physically exist until something else is written over them. You can use some programs to completely erase it (write layers and layers of blank files over the old ones) but that's for the people who really are hiding some shady stuff. :D
https://linustechtips.com/topic/126512-how-to-format-hard-drive/#findComment-1682574
While we're at it. Can anyone recommend a program to format a hard drive compeletley, so that it can't even be recovered anymore? Something that puts like 6-7 full write and read cycles over your data so you can sell it?
who cares...
https://linustechtips.com/topic/126512-how-to-format-hard-drive/#findComment-1682591
DBAN is widely regarded as the best free utility for this. I use it all the time at work.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
https://linustechtips.com/topic/126512-how-to-format-hard-drive/#findComment-1682608
But I really wanna remove all the things as I don't wanna waste any space on the hard drive
When Drown said formatting deletes the references for them, your drive will act no differently than if it was completely empty space. Your computer just sees the space with previous data as empty because there is no reference, and writes to is as such.
If it's a security issue you're worried about, check out DBAN which will write over all the space with random data and make anything previously there essentially unrecoverable.
https://linustechtips.com/topic/126512-how-to-format-hard-drive/#findComment-1682620
