Advice on CLC AIO: Found One, Need Fact Check
Solved by RollinLower,
36 minutes ago, sowon said:Sorry I wasn't specific, I meant it fitting inside the case.
The NZXT S340 has this black bar thing near the front of the case, and as you can see from this Gamers Nexus screenshot, that AIO is getting its hairs trimmed, so I was wondering if I might have troubles with the radiator plus fans fitting in.
you answered your own question by posting a picture of the case with an AIO installed.
fan dimensions are norrmalized. meaning all 120mm fans should be the same height, diameter and length.
same with radiators. the fact that one slim 240 fits means that all slim 240's should fit.
