5700 XT replacement pads?
Guest
Thinking about giving replacing the thermal pads (and paste) on my MSI RX 5700 XT MECH OC a shot in hope to lower the temps a bit, but I've never done it before and am unsure on what thickness for the pads I should use. Has anyone done this before who could give me some tech tips?
Really, you can just use thick globs of thermal paste. It's slightly more effective, but you need a thicker paste to do it. Prolimatech PK-3 is what I've used for my GPUs as a "total replacement" paste.
CPURyzen 7 5800X Cooler: Arctic Liquid Freezer II 120mm AIO with push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
MotherboardASRock X570M Pro4 GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO Case: Antec P5 PSU: Rosewill Capstone 750M
Monitor: ASUS ROG Strix XG32VC Case Fans: 2x Arctic P12 PWM Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
Isn't there a high risk of overflowing on the memory chips since they're so small, or do you just use a tiny amount?
The memory chips are about a half inch on the smallest size, and the contact points are underneath the chips. Use a full-on pea sized glob in the very center of the chip, and it'll both cool it sufficiently, and not overflow it. If you use a more liquid paste, or an electrically conductive/capacitive paste (like Arctic Silver) you will have significant risk however.
Thick paste, with low dryout, and not electrically conductive, is what you want. As long as you're not doing a vertical mount, any post-installation paste shifting will simply spread out along the heatsink, not drip against gravity up onto the GPU's PCB.
Do you use the same paste for the graphics processor itself or a more liquid-y one?
I have an Asus 5700XT and my best suggestion is to watercool it. that thing runs hot and even after i pulled it apart and changed the thermal pads and paste it didn't do squat. i dropped about 25c when i switched it to a waterblock.
Same paste. PK-3 is the least expensive per-ounce I've found that can get within 1°c of the performance of Kryonaut. The liquidity of the paste has no effect on performance.
A waste of money. Better to spend the extra on getting a newer better GPU than waste money on watercooling this GPU.
I haven't seen any posts about thermal pad thickness on 5700 XT boards.  Did you check the teardown videos?
I know the reference Vega 64 used 1mm pads, with either 1.5 or 2mm for one of the VRM mosfets.
Your best bet is to buy a 145x145 sheet of 0.5mm, 1mm and 1.5mm Arctic pads, then compare them to the original, and stack whatever is thicker than 1.5mm.  The prices increased a lot compared to last year however.
  • 5 months later...
I have a 3 5700xt raw II GPUs and I'm trying to replace the thermal pads. Does anyone know what the thickness is for those thermal pads that came with. I bought some thermal pads already but they are too thick. Any know, I'm dieing over here.
What thickness did you buy? Are they too thick to be able to squish them down when tightening down the cooler? (would provide the best contact if it's possible)
  • 2 weeks later...
Hello, I have the same card mentioned. Did you ever find the correct thickness? Im estimating that they’re between 2mm and 1mm. Thank you in advance!
It depends on the pad type. The one that was originally used for the memory on the reference board was a clay-type pad, and was 2mm before compression, but slightly less than 1mm after. If you were to try it with the rubber style pads, 1.5mm would be a better idea.
