Cooling capacity on 480mm XE EKWB rad with 3000RPM fan
25 minutes ago, TheNaitsyrk said:I was only curious why BlackIce 420mm rad same thickness as EKWB one is rated at 1800W and EKWB one is 957W or 1190W or so whilist EK one is bigger. Just wanted to see if faster RPM = better W dissipation and if it can be measured in meaningful way.
Unless you can create a constant and regulated thermal load on the Cooling system it is almost impossible. even if you do so you will have to eliminate one of the 3 variables: Fan speed, DeltaT, Rad properties (fin area, density restriction and so on)
I think it is all marketing BS. The difference between these 2 rads is minimal and the results published by the manufacturer is not good for fair comparison.
All I can really tell is my 240-60mm barrow rad can cool my overclocked flashed vega56 into 64 and 9400F which both produce up to 450 watts (according to HWinfo and GPUz) of heat with deltaT of around 15-16C and fan speed of 2000rpm on Noctua NFA12X25. Thus the reasonable figure is around 1000watts for a 480 "thick" rad.
If deltaT is increased it can handle more, If fan speed increased it will handle even more.
Here is some research made by Thermalbench.com both of them look more a less the same.
http://thermalbench.com/2016/11/22/hardware-labs-black-ice-nemesis-gtr-480-radiator/5/
http://thermalbench.com/2015/06/07/ek-coolstream-xe-480mm-radiator/5/
