CPU cooling? HELP
Solved by Blecter,
What are the big draw backs of that 212 evo?
Anything that could be crippling or is it of solid build quality and worth the purchase cause that price is wonderful if it is good.
My only concern is good build quality and will work.
The 212 Evo is solid and works excellent. I've got it set up with the fan that comes with it, and my i5-4670k @ 4.4GHz stays around 45C (+/-5C) while gaming heavily/using real world applications, and around 65C when stress testing. No complaints, and would easily recommend it, especially for the low cost.
