Is seasonic core-gc better than Xilence XP600R?
dens22
So, I upgraded my psu recently from Xilence XP600R to Seasonic Core GC-650. Did I just dodged a psu failure, and saved my pc, or wasted my money?
Assuming that your previous PSU was a Xilence Performance C, you didn't waste your money at all. You had a low-end PSU with low durability components, and now you have a more than decent model which should work reliably for at least 7 years. I don't see the problem! Maybe you didn't save your PC in the sense that the Performance C didn't seem terrible enough to kill your components, but you made a good replacement anyway. Enjoy your new PSU ^^
While the Core is pretty low end, the XP600 is complete garbage.  So yeah.. you did an upgrade.
  • 2 weeks later...
Should I be worried about that?
Since I don't know what you're using it to power, I can't answer.
Here are my specs:
Ryzen 5 1400
ASUS PRIME A320M-E
16 GB of RAM
RTX 2060 super
6 hours ago, dens22 said:
Here are my specs:
Ryzen 5 1400
ASUS PRIME A320M-E
16 GB of RAM
RTX 2060 super
With those specs, you are fine.
MAIN PC:
CPU: Intel® Core™ i9-9900K Processor  Motherboard: Gigabyte Z390 Aorus Pro Wifi  CPU Cooler: Scythe Fuma 2  GPU: EVGA RTX 3080 FTW3 Ultra  RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red  Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
SECONDARY PC:
CPU: Intel® Core™ i3-9100F Processor  Motherboard: ASRock Z390 Phantom Gaming 4-CB  CPU Cooler: Arctic Alpine 12 CO  GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16
Case: CyberpowerPC Onyxia  PSU: ATNG ATA-B 800w 80 Plus Bronze  Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM    OS: Windows 10 Home
Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti
