Seems pretty straight forward.
"Direct3D could not allocate sufficient memory to complete the call"
MOTHERBOARD: ASRock H97 Pro4 CPU: Intel Core i5-4460 @3.30 Ghz Intel Xeon E3-1271v3 @4.00 Ghz RAM: 32Gb (4x8Gb) Kingstone HyperX Fury DDR3@1600 Mhz (9-9-9-27)
GPU: MSI 390 8Gb Gaming Edition PSU: XFX TS 650w Bronze Enermax Revolution D.F. 650w 80+ Gold MOUSE: Logitech G502 Proteus Spectrum KEYBOARD: Monokey Standard Suave Blue
STORAGE: SSD Samsung EVO 850 250Gb // HDD WD Green 1Tb // HDD WD Blue 4Tb // HDD WD Blue 160Gb CASE: Fractal Design Define R5 Windowed OS: Windows 11 Pro x64 Bit
MONITORS: Samsung CFG7 C24FG7xFQ @144hz // Samsung SyncMaster TA350 LT23A350 @60hz Samsung Odyssey G7 COOLER: Noctua NH-D15
https://linustechtips.com/topic/1255827-directx-problem/#findComment-14100976
He needs to buy a better GPU, the 940MX was never a gaming GPU to begin with and it simply doesn't have enough RAM to run anything even remotely modern, even at low settings.
Main Rig:-
Server:-
https://linustechtips.com/topic/1255827-directx-problem/#findComment-14100981
It's a Laptop
Is there something else we can do ?
I can see that
What to do ?
17 hours ago, SkilledRebuilds said:
Once GPUVideoRAM is full it tasks SYSRAM (Not always the amount you have, but less) VirtualRam
It's all Full.
So will increasing VRAM do any good ?
https://linustechtips.com/topic/1255827-directx-problem/#findComment-14100992
1 hour ago, SladeDJWilson said:
I can see that
What to do ?
Either upgrade the GPU, system RAM, or both. If those aren't possible with the laptop then your friend is likely out of luck.
GPU incredibly unlikely to be able to be upgraded. RAM is possible provided the slots are accessible and the modules aren't soldered.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1255827-directx-problem/#findComment-14101242
19 hours ago, SladeDJWilson said:
A friend of mine is getting this error.
What to do ?
Some more context might be useful.
What laptop is it? What version of Windows?
Has the game ever worked or has it always given this error?
At what point does the error occur? ie, does it happen while loading, or once you are in-game?
https://linustechtips.com/topic/1255827-directx-problem/#findComment-14103324
19 hours ago, mahyar said:
that doesnt matter what resolution are you playing at
It might be possible to lower the texture resolutions if the game has some user-editable settings files (.ini, .cfg etc). Or it might be possible to force them lower with some GPU driver tweaks. Need more info though, and ideally someone that know about the game in question.
https://linustechtips.com/topic/1255827-directx-problem/#findComment-14103328
