3080 Problems
By
SirSneez
in Graphics Cards
in Graphics Cards
Solved by Bad5ector,
Are you using a riser cable by chance? I had that same issue with my old 1080ti with a crap extender that came with my Thermaltake Core P3 case. Once I plugged in direct to the mobo, problem solved. Ended up purchasing a beefier extender cable and that also fixed it up.
3
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases5 -
2
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning18
play_circle_filled
Latest From ShortCircuit:
