3080 Problems
Go to solution Solved by Bad5ector,
Are you using a riser cable by chance? I had that same issue with my old 1080ti with a crap extender that came with my Thermaltake Core P3 case. Once I plugged in direct to the mobo, problem solved. Ended up purchasing a beefier extender cable and that also fixed it up.
Hi everyone!
Second post about my problems with my TUF 3080. The lingering issue is that once I “install” the Nvidia drivers, GeForce Experience will continue to show what I have to install them, Windows will keep throwing up a loop of notifications to “force reinstall graphics driver”, my monitor will constantly turn on and off again, and opening chrome or file explorer will cause the PC to seize up, restart itself, and uninstall the graphics driver. I’ve changed out the mobo, ram, and PSU and nothing has changed. I have even installed a fresh copy of Windows and that didn’t help. This is my second 3080 this week that has been showing the same issues. Any help is greatly appreciated. Thanks!
https://linustechtips.com/topic/1254296-3080-problems/
Post system specs including the PSU, model and wattage.
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086630
2 minutes ago, NadeMagnet69 said:
Your second? How did you manage to get more than one? lol Scratch that, how did you manage to get 1 to begin with?
I haven't even seen any in stock at all, 3080 or 3090....
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086644
Stood in line at Micro Center for 3 hours. Bought the 2 year protection. Returned the first for a TUF card that was held for me on shipment.
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086657
1 minute ago, SirSneez said:
Ryzen 3700x (no OC), 32 gb g.skill trident neo 3600mhz (4x8), EVGA SuperNova 850W, and the Asus TUF 3080
Using 2 separate PCIe cables?
Or one daisy chained...
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086659
2 minutes ago, SirSneez said:
Two separate PCIe cables
How old is that PSU?
And what Supernova is it?
NVIDIA has a hotfix driver out... ;)
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086663
Make sure you update Windows 10 fully just incase you haven't....
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086670
3 minutes ago, SirSneez said:
EVGA Supernova 850 GA (80 Plus Gold). I replaced it today. So it’s brand new.
Windows updated?
MB drivers etc?
Using the cables that came with the PSU?
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086675
What's the Motherboard?
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086680
Aorus x570 Pro Wifi
Got both EPS cables connected?
8 Pin and 4 pin?
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086687
6 minutes ago, SirSneez said:
Yup
OK, just checking off the boxes....
Just incase.
Get the NVidia hotfix driver. 456.71
https://nvidia.custhelp.com/app/answers/detail/a_id/5091
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086714
I will attempt to install and will let you know of the results.
Choose clean install.....
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086721
So I attempted a clean install of the driver you linked. It finished installing but the system isn’t recognizing the GPU anymore. And when I open GeForce Experience, it says I need to install the latest driver (456.55)
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086792
OK, bad card.
https://linustechtips.com/topic/1254296-3080-problems/#findComment-14086795
