RTX Voice suppressing my voice instead of noise??
Solved by .Apex.,
2 hours ago, Ash_Kechummm said:I'm using the standalone RTX voice, I only have a 1660 Super, so no compatibility with broadcast. Also, the silences in the middle of my recording? that was RTX on and i was trying to speak. Sorry I forgot to mention it in the original post!
The 1660 Super doesn't support RTX voice, since you bypassed the installation then it isn't guaranteed to work properly
also I'm aware of when you enabled it, but I did it on my machine to the beginning of the clip and it got rid of the noise
