Maybe this is a dumb question. I have an h100iv2 for my cpu on the front panel and an evga 980ti hybrid gpu, rad on the rear panel. Both are set to intake with a single exhaust fan on the top. With these components both drawing fresh air rather than relying on case flow/fans, does my case really matter? Currently have an s340 case and ideally will be upgrading to an evga 3080 20gig hybrid when it is released
https://linustechtips.com/topic/1250309-does-case-airflow-matter/
Yes case airflow matter.
If you don't have a proper airflow, heatsink will reuse the already hot air it produce, again and again, adding more heat with each loop. Making the cooling ineffective.
Yes and no - technically if you are within the realm of operating temperatures as rated for the equipment, it doesn't matter.
To me, it matters.  Thermals, airflow, case design.  In the end I don't want to hear my PC running, sweat in the summer during long gaming sessions because my room superheats, etc.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Yes but cpu and GPU are both water cooled and draw fresh air from the front and back panels so they aren’t recycling hot air in the chassis
1 hour ago, blakslee720 said:
Cpu is in the low 70s during Cinebench. GPU in the 50s gaming (both ar OC’d)
This should be ok.
