Help me to fix this headset problem - microfone not working
Solved by AndreiArgeanu,
8 minutes ago, lorcav123 said:I think his motherboard is this one
https://www.asus.com/Motherboards/M5A97_R20/
Case is some cheapest possible...
The motherboard doesn't have one of those ports. And the case probably doesn't have it either. It's pretty common for this to happen even with modern hardware and as I said your only solution to get the microphone and headphones working at the same time is to get an adaptor. Or a separate mic.
