cpu Can I troubleshoot CPU without Fan?
Solved by Aditya Dighe,
As per this video you can. ( The video creator doesn't recommend it)
Recommended - Not At All Recommended,
it can die within seconds, temperature of transistors rise very rapidly, you won't be able to touch it , even if it runs for mere 2-3 seconds
If you atleast have heatsink on top of it, it is just a bit safer..
If trying - try at your own risk
