Doubling up on AIO fans?
Hello! I just upgraded my cpu from a 3700x to a 3900x.  I have a kraken x72 aio on my system.  I was wondering if there would be any measurable benefit of putting fans both on top and under neath the radiator?  There are mounting points on both sides of the radiator, and I was curious if there would be any difference getting 3 more fands and doing a push – push or push – pull setup on the radiator.  My idea behind this was that if I keep the air moving through the radiator faster, the greater volume of air would absorb more heat to cool down the coolant. I was wondering if any one had tried this and noticed anything!
Welcome to the forum!
Depending on the case and setup it can make a decent difference. In my use case I was able to lower CPU temps and fan RPM in a push-pull config. The biggest concern is making sure you have the space in your case. Not necessarily worth the $$ investment of 3x more fans, as you will want to make sure they are the same fans you already have/ get a whole new set of 6 identical fans.
Really up to you. Does it yield a good cash to performance yield? No. Is it required for your use case? No. Will it lower temps, most likely yes (within 4-8 degrees under load).
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Instead of doubling the fans, make sure fans mounted on radiator have sealed edges/corners. Use square fans that are snug against the radiator frame. If fans are those fancy anti-vibration ones with cut out corners and lifted rubber, they'll leak pressure. Or suction, depending whether they are push or pull. I had to cut out thin layer of plastic that I placed between radiator and fan which seals these corner gaps on my SilentWings 3. It's basically plastic the size of radiator opening and with hole cut into it, to fit the fan opening perfectly. So air can only pass through the fan blades and through the radiator fins and not bleede out on the sides of the fan before it can even push it through radiator fins.
You can simply use packaging plastic. Motherboards usually have large clear plastic cover inside the box. Fan packages often have plastic blister that's slightly larger than fan itself which can also be used for such purpose. Plastic is super thin, but still rigid enough and can easily be cut with scissors or any kind of sharp blade like modeling knives/scalpels. Drill or punch holes in corners for screws to pas through and sandwich it between fan and radiator. Also don't be scared if fans lose some RPM because of that as they'll be working a bit harder, but won't be leaking any air pressure.
Most of the tests I see yield 2-3C improvement with push-pull.
If you have the space and the extra fans at your disposal then yeah, give it a try. Wouldn't expect a drastic change in performance though. Might not be worth the investment if you were expecting some huge drop in temps.
As a side note, I don't think push-push would be a good idea period.
  • 2 years later...
I have doubled fans. On front is a low speed NZXT fan. On the rear is a high speed Delta server fan throttled down to run at 2200rpm max. I had my USB 3.2 cable block the server fan but the low speed fan still spun and kept the CPU at a safe temperature.
Dual fans increase pressure, hence increase flow, and also provide a bit of redundancy.
