Hey guys, i recently built a new PC containing the Gigabyte RTX 2070 Super Windforce OC 3x 8gb.
I've been getting lower performance compared to similar builds. When playing the new Control: Ultimate Edition, I get drops below 50 fps (RTX high, fast Vsycn on, 1080p), and have 0% GPU Usage, other games don't have the 0% issue, but poor performance when compared to similar builds. I average at around 50fps on this game and ive seen builds average at 85fps.
While playing Anthem i get drops below 60fps playing in 1080p ultra. (Dlss off, Fast Vsycn on), average around 55fps
This is the benchmark I'm comparing to, the uploader has stated that he's not used any OC: https://www.youtube.com/watch?v=rmwc5hV43oU
My Build:
                 MOBO: Aorus B550 Pro AC
                 CPU: Ryzen 7 3700x
                 GPU: Gigabyte RTX 2070 Super Windforce OC 3x 8gb
                 RAM: Gskill TridentZ 32gb (16x2) 3200Mhz
                 PSU: XPG Core Reactor 850w gold rated
                 NZXT Water Cooler X52 and the NZXT H510 Cab.
                 Monitor: Dell 1080p 60hz
3D Mark Timespy Score: https://www.3dmark.com/3dm/50369409?
3D Mark Firestrike Score: https://www.3dmark.com/3dm/50373268?
*All drivers and Bios upto date.
*XMP is turned on.
*Stock profiles for CPU and GPU.
*The temps go upto to 70*C on the GPU
*The CPU runs at 30-50% with temps low.
*Not that big a performance rise with Geforce Experience disabled.
Would love some insight.
Hey guys, thanks a lot for the replies. The card was connected into the PCIE 3.0 x4 slot instead of the PCIE 3.0 x16, I also replaced the single PCIE cable that's split into two connectors with 2 PCIE cables.
https://linustechtips.com/topic/1247091-solved-help-rtx-2070-super-underperforming/
Try heading over to the Nvidia Control Panel and under manage 3d settings, change the power management mode to maximum performance
Main Desktop:
Intel Core i7-13700KF (5.5GHz, -0.1v Offset), Lian Li Galahad 360 AIO, Asus ROG Strix Z790-A Gaming WiFi, Gigabyte RTX 4070 Ti Super Aero OC, 2x16GB G.Skill Trident Z5 RGB DDR5-6000 CL36, 4TB Samsung 990 Pro, Corsair RM850x Shift, Phanteks NV5 w/ Lighting Kit
Peripherals:
Alienware AW3423DWF QD-OLED, Logitech G502 X Plus, SteelSeries Aerox 3 WL 2022 Snow, HiFiMan Sundara, Sennheiser HD 560s, Cooler Master MH630, Schiit Modi 3e, Schiit Magni Heresy
Laptops:
Asus ROG Zephyrus G14 (Ryzen 9 8945HS, RTX 4060)
Phones:
Samsung Galaxy S24 Ultra 256GB, iPhone 14 Plus 128GB
try turning vsync off.
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
vsync would not do that.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
does vsync not try to sync the fps with your monitor's refreshrate?
or did i misunderstand how it works,  because similar things happened to me when i used vsync
It can lower preformance, but he said drops, and vsync would be steady. I lost like 5-10 frames on most games when I turned on vsync, not like 30.
Bios database
prior build:
could just be me when i used vsync then
Hey! Thanks for replying, I've done that, games still run slower
There are different types of Vsycn, "fast" Vsync does not limit to the monitor's refresh rate!
never seen that one before, maybe it was just renamed or i overlooked it.
but in general i've heard people saying that playing with it off is often better than playing with it on
Thats actually false because screen tearing feels pretty ugly, turning it off increases performance, by decreasing performance (causing screen tearing) ahahahah, and in the video that i'm comparing i see no screen tearing going on so i assume he's turned it on.
You can find it in the control panel 3D settings under Vsync.
Yeah but don't use Nvidia vsync if your game has a vsync option then use that instead.
Nv vsync seriously is a performance killer and not really necessary when the game has an option for it.
-Scott Manley, 2021
I don't know about Control but on my 2070 Super I had slowdowns from 120 fps to the mid teens, sometimes as low as 10 fps in COD MW when I had RTX enabled and fire or an explosion would happen .. is there an RTX setting in control you can toggle ? I knew there was something up because I never had slowdowns in Warzone and when I read that WZ doesn't support RTX I clicked it off and boom .. solid 120s
Hey! The in-game vsync option caps my framerate at 60fps which limits the GPU usage as well, (60%)  and i experience drops lesser than 54 fps etc, which is worse because it's capped. Fast VSync uses 100% of the gpu,does not cap and eliminates screen tearing based on the card's capability, so i prefer using that. Anyone have insights on the 0% for Control?
Yes there is! But if you can check the youtube link i posted  https://www.youtube.com/watch?v=rmwc5hV43oU , you'll see his settings are maxed out with RTX on HIGH. He averages around 85 fps, My average would be around 50 or lesser
Huh, ok I guess it depends on the GPU for me the ingame vsync usually has the least issues.
-Scott Manley, 2021
Do you have DLSS enabled?
CPU: Ryzen 7 5800x3D || GPU: Gigabyte Windforce RTX 4090 || Memory: 32GB Corsair 3200mhz DDR4 || Motherboard: MSI B450 Tomahawk || SSD1: 500 GB Samsung 850 EVO M.2 (OS drive) || SSD2: 500 GB Samsung 860 EVO SATA (Cache Drive via PrimoCache) || Spinning Disks: 3 x 4TB Western Digital Blue HDD (RAID 0) || Monitor: LG CX 55" OLED TV || Sound: Schiit Stack (Modi 2/Magni 3) - Sennheiser HD 598, HiFiMan HE 400i || Keyboard: Logitech G915 TKL || Mouse: Logitech G502 Lightspeed || PSU: EVGA 1300-watt G+ PSU || Case: Fractal Design Pop XL Air
