I have a ryzen 7 3800x and a rx 5700xt with a mpg x570 gaming edge mob I have not done any over locking because I don't know how but it seems like my cpu and gpu are bottlenecking my gpu stays in the 50's and my cpu is all the way up to the 80's and 90's is there anyway to fix this?
https://linustechtips.com/topic/1246612-need-help-cpu-and-gpu-bottlenecking/
That’s not going to bottleneck
Hi
hi
it depends on the game what that gams uses. some use gpu some use cpu some use both saome like more cores some like more ram some like higher clocked cores. all depends on the game.
bottle necking is were say the cpu is at 100% and you upgrade the cpu and it drops down to say 80% that means that that cpu was at its max and could use more power.
Like the others said, that depends on the game. But overall you have a very balanced system where no component will be held back by another.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
If your talking about temps then that is not what a bottleneck is.
But your CPU and GPU do not bottleneck
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
