Im building a dedicated streaming PC for my church, plan on using OBS and live stream to facebook. Wanting to stream at 1080P but can do 720P as long as its clear. This is the build i have pieced and was wondering if anybody with similar stream experience could tell me if this is overkill, good to go or needs more (such as a capture card). I have never streamed before so am unfamiliar with that world.
Component   Selection Base Promo Shipping Tax Price Where
CPU   c7baf2c9c9cc15ae23adb24c2f4316fc.256p.jpg AMD Ryzen 5 3600 3.6 GHz 6-Core Processor $209.99   amazon-prime.png   $209.99 logo2_merchant_amazon.png Buy
Motherboard   491312c7eb6c3a47c8a7c53e063b397e.256p.jpg MSI B450-A PRO MAX ATX AM4 Motherboard $99.99   FREE   $99.99 logo2_merchant_newegg.png Buy
Memory   a00199d12cb22ee1dc33639a754cca79.256p.jpg G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory
From parametric filter: Form Factor: 288-pin DIMM; Speed: 3600 - 5000; Modules: 2 x 8GB; CAS Latency: 3 - 16
$69.99   FREE   $69.99 logo2_merchant_newegg.png Buy
Storage   567dfd409067c0a10aa67fc3c720c46d.256p.jpg Team MP33 512 GB M.2-2280 NVME Solid State Drive
From parametric filter: Capacity: 500 GB - 16000 GB; Type: SSD; Form Factor: M.2-2280; Interface: M.2 (M)
$53.99   amazon-prime.png   $53.99 logo2_merchant_amazon.png Buy
Video Card   9c0a8124637c1148bfc298a9fd52f622.256p.jpg Gigabyte GeForce GTX 1660 SUPER 6 GB GAMING Video Card
From parametric filter: Chipset: GeForce GTX 1660 SUPER; Length: 223 mm - 403 mm; Cooling: 2 Fans, 3 Fans
$239.99   FREE   $239.99 logo2_merchant_newegg.png Buy
Case   4fb6248b59678b0c8d394a23116d1ee3.256p.jpg Cougar MX330-G ATX Mid Tower Case $44.99   $6.99   $51.98 logo2_merchant_newegg.png Buy
Power Supply   d0942c9c2e9216eccf77b6a59fbca6b0.256p.jpg EVGA GD (2019) 500 W 80+ Gold Certified ATX Power Supply $79.98       $79.98 logo2_merchant_amazon.png Buy
Operating System   f5e3c78aadf16d536c31b0fa088c8306.256p.jpg Microsoft Windows 10 Home OEM 64-bit $108.78   FREE   $108.78 logo2_merchant_otherworldcomputing.png Buy
Case Fan   a73149881193fcdb1dcabe7140f0c353.256p.jpg Corsair AF120 (2018) 52 CFM 120 mm Fans 3-Pack $39.99   FREE   $39.99 logo2_merchant_newegg.png Buy
Monitor   e90268dd70da5f4098e1b8b33e5ab79b.256p.jpg LG 24M47VQ 24.0" 1920x1080 60 Hz Monitor $99.99   amazon-prime.png   $99.99 logo2_merchant_amazon.png Buy
Keyboard   51kutVf-p7L.jpg Redragon K552 Wired Gaming Keyboard $37.99   amazon-prime.png   $37.99 logo2_merchant_amazon.png Buy
Mouse   82959eefb4e00fe12bf0c9ae9c6ea5dc.256p.jpg Logitech M330 SILENT PLUS Wireless Optical Mouse $14.99   FREE   $14.99 logo2_merchant_bestbuy2.png Buy
https://linustechtips.com/topic/1245409-church-stream-pc-build/
what device will be used to record? how does it interface with the PC?
overall it's a very overkill PC for the job
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14010030
You'll need a capture card to go from your camera to the PC. If you have more than one camera, that changes things too. You'll also need to figure out how you're going to get audio as well. Are you gonna go from the mixer into the PC, or use whatever the camera has? Personally, I'd go from the mixer to the PC as it would sound more clear.
https://www.amazon.com/Elgato-Game-Capture-HD60-Pro/dp/B014MQIVPS/ref=pd_lpo_147_t_1/142-6449688-0419128?_encoding=UTF8&pd_rd_i=B014MQIVPS&pd_rd_r=070c9fe3-9734-4074-9176-eeb21d4a81b9&pd_rd_w=XbTKw&pd_rd_wg=3tK80&pf_rd_p=7b36d496-f366-4631-94d3-61b87b52511b&pf_rd_r=ZCG96RYE6SNV9F3ENQC9&psc=1&refRID=ZCG96RYE6SNV9F3ENQC9
If you're gonna take your audio from the mixer, you'll first need to figure out what kind of outputs your mixer has. Some you can just use an RCA to 3.5mm cable and go right into the sound card on the motherboard. If not, you may have to go XLR out, which may require an audio interface (I don't like those XLR to 3.5mm cables, they never sound right to me).
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14010034
Agreed - why does he need a GTX 1660 in there? You can stream using an Intel iGPU if you need to.
Aside from that, if you're putting in a powerful GPU, then you don't need a powerful CPU - and vice versa. If you use a software encoder, it'll use the CPU. If you use a hardware encoder, it'll use the GPU (whether discrete via NVENC, etc, or integrated via QuickSync).
QuickSync should be 100% sufficient for a church's needs.
If they have the budget, and specifically want some higher end components, like an NVME SSD (overkill unless amazing value), that's one thing. But these components are simply not required.
I would include an i5 (has it's own iGPU) or Ryzen 5 and the cheapest lowest end GPU - or I would replace the Ryzen 5 with the absolute cheapest AMD CPU plus a low-ish end or older mid-range GPU (1660 is still overkill even here).
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14010047
super overkill, i'd look at a i5-10500, 16GB RAM, 240GB SSD and 2TB+ HDD (added storage for regular backup image to restore quickly if it goes down)
integrated GPU is perfect for a simple stream, some cameras have built in "webcam" software so it might save you from needing a capture card.
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14010053
i would say having a 1650 super is nice for NVENC Turing (for a little bit better visual quality, quicksync  is dead in my eyes, so is AMD's encoder.)
alternatively, software x264 is fine on medium/slow, which is slightly lower quality than NVENC Turing
it is also very heavy on CPU, which he may need to process captured audio/video footage.
so if he wants a GPU, 1650 Super is good enough, any other 16/20 series gpu uses the same NVENC (other than 1650, which uses NVENC Volta, which is slightly inferior to x264 medium in most cases)
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14010057
Thanks you all for the replies, that is exactly what i was afraid of doing because my PC knowledge (while very limited) is gaming and when doing lots of research most of what I found was how to stream/game or stream to twitch and such from console and so forth. We do have a camera (nice panasonic but i don't remember exact model) and we were streaming before but had two problems. One was the internet connection which has been fixed, the other was a Lenovo all-in-one that just couldn't keep up with encoding and uploading which is what i'm replacing. Stream would be very choppy and buffer and audio would be off time often. A lot of this was setup prior to me getting involved. We are getting audio directly from the mixer. With no real knowledge of streaming very open to suggestions on how best to go about this whether CPU x264 encoding or NVENC on a 1650 Super. I just remembered that we already have a Magewill (I believe) HDMI capture card for the Camera to computer. Once again i really appreciate the answers and certainly sounds like i can back it off and save some money.
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14010091
-= Topic moved to New Builds and Planning =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14010096
As others have said, this is super overkill.  You should be well-served with a moderately powerful workstation build.  No GPU needed, just a decent CPU.
Unless you have poor ventilation or the room is warm where your PC will be, I also don't think you need to shell out for additional fans.  Just use what comes stock with the case and CPU.
Add your own choice of peripherals and this should be a decent build for what you're looking to do.
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14010460
Keep in mind that Ryzen 5 2600 does not have an iGPU. You'll need to add a cheap GPU (literally the cheapest one on sale, like a GT710 or an HD5450).
Alternatively you could grab a Ryzen APU instead, like the Ryzen 5 4600G or 4600GE - those have integrated graphics. (The G is 65W while the GE is 35W TDP).
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14011386
What?  Well frick.  @Ansem117 see above.
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14014991
Yeah it's annoying, but it was a strategic decision that AMD made to:
1. Lower the manufacturing cost per CPU
2. Help differentiate the regular CPU's from the APU's
Not too big of a problem, I think - just grab a $40 GPU, or switch the Ryzen 5 CPU out for a Ryzen 5 APU instead (note you'll want to check board compatibility).
https://linustechtips.com/topic/1245409-church-stream-pc-build/#findComment-14015004
