It'll be enough if you aren't going for record overclocks, but two cables is better if you've got access to that.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1244753-pcie-cables-for-3080/#findComment-14004243
You can buy individual cables from sites like cablemod.com
Only buy a cable if it says it's compatible with your model of power supply.
Some manufacturers use different pinouts compared to other manufacturers, or different connectors, so a cable from one psu may not be compatible with your power supply.
Even if they're two psu's from same manufacturer, no guarantee they're the same pinout (same order of wires in connectors). Some are better than others... for example Seasonic's power supplies from a few years back until today all have same cables, they went through 3 "revisions" until they settled to this last format
Manufacturers like evga and corsair will have lots of different cable pinouts because they use models from various OEMs each with its own pinouts.
https://linustechtips.com/topic/1244753-pcie-cables-for-3080/#findComment-14004259
