Noob question about fan curves and issue with fan
On 9/9/2020 at 2:54 PM, TristanN said:Yeah sorry, I no longer have the fan ramping up/down quickly, I just wanted to make sure the fan curves and temps are alright.
There's no "right" or "wrong" way to setup fan curves. They are really representation of what you like and want. Temps are relative to stress, CPU, voltage and so on. Without knowing what CPU voltage was under stress testing, its hard to say anything about it. 78C is higher than what it should be. Cinebench is not that heavy. But then again, if you have PBO set to auto, that might be contributing.
With curves, you are selecting between two options. Temps and noise. Nothing else really. Less noise means higher temps are you are setting fan speed slower. CPUs (everything Intel and AMD Ryzen) are fine up to 80C+ under full stress load. Each person has their own preferenced there too, mine is 87C under full stress testing. GPUs are fine to 85C, my own gaming temp is 80C because of too high fan noises.
