i7-10700k overclocked to 5.1ghz and RTX 3080, is an 850-watt PSU enough? Got a Corsair RM850x in preparation for the upgrade, but after deciding on overclocking, I'm wondering if I need more juice. What do you think?
Other components in the system:
- 1x m.2 ssd
- 1x standard 2.5" ssd
- 6x 120mm RGB fans
- 1x Corsair Hydro 150i Pro RGB
Might add a standard HDD, but I have no intentions on adding an optical drive.
https://linustechtips.com/topic/1244517-psu-for-ampere/
Wait for ampere and check the 3080's power consumption, but for the most part, 850w should be more than enough.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1244517-psu-for-ampere/#findComment-14002338
You could throw a 3090 in there and still have room to spare. You're fine.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1244517-psu-for-ampere/#findComment-14002339
- 1x m.2 ssd
- 6x 120mm RGB fans
Even Corsair is "only" suggesting 850 when siding with caution.  You're more than fine.
I believe Nvidia is only suggesting 750W.
https://linustechtips.com/topic/1244517-psu-for-ampere/#findComment-14002394
