2 minutes ago, AndrewZScorpion said:
It shows it changing color on their website, so if it isn't, they'll have some explaining to do.
https://www.asus.com/Graphics-Cards/TUF-RTX3080-10G-GAMING/
Thanks. Need to find out all I can before the launch, so that I can snag one the minute it comes out. Was originally going to buy the 3070, but the 3080 is only 1600nok (150usd) more expensive due to some weird pricing models here in Norway.
https://linustechtips.com/topic/1244470-rgb-or-not/#findComment-14002028
10 minutes ago, DeagleMaster said:
Is the light on the 3080 TUF rgb or not. I know it might sound like a silly questions, but I can't for the life of me figure it out.
That link provided does say you can customize RGB with Armoury Crate software and also provides a basic sample of the RGB modes.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
https://linustechtips.com/topic/1244470-rgb-or-not/#findComment-14002040
