Hi.
I just built a new pc but the GPU is giving no signal to the monitor.
The specs are:
Asus TUF B450 PLUS GAMING
Ryzen 5 3600X
Crucial ballistix gaming memory - 16GB (2x8) DDR4-3200
MSI geforce 2080 super (gaming trio)
Mars gaming MPB650
When I switch it on the fans work and the lights are on, but I can't see anything in the monitor. I'm using the HDMI (i cannot use the displayports by now).
I'd realy appreciate it if you guys could help me. Thank you!! :)
UPDATES:
- the hdmi is connected to the video card
- tried with an only ram stick.
- tried with and without the gpu (obviously nothing happened)
- cmod cleared and mobo battery removed for 5 minutes.
I don't know what else I can do :(
https://linustechtips.com/topic/1244051-help-please/
Just now, Parth2105 said:
Is HDMI plugged in the video card port? If it is then I suppose you got a dead component, though you better seek someone more well versed with pc building and not take my word for it.
Yes, the HDMI is plugged in the video card port. The 2080 shouldn't be dead, it was working yesterday in another pc.
https://linustechtips.com/topic/1244051-help-please/#findComment-13998717
Plug your HDMI into the GPU, not the mobo. Clear CMOS (look into your mobo manual for that). Reseat your RAM. Try 1 RAM stick at a time. Check all internal cables and if everything is fully plugged in.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1244051-help-please/#findComment-13998718
Ryzen 5 3600X - MSI geforce 2080 super (gaming trio)
Ensure you're connected to the videocard and not the motherboard. Make sure the monitor is set to the correct input as well.
Check the motherboard box front if this graphic is present:
If you have another monitor to test the system out with - or even a TV - please do try, to be able to remove some variables from the test.
https://linustechtips.com/topic/1244051-help-please/#findComment-13998720
Thanks for your comment. I've tried everything but it doesn't work :(
https://linustechtips.com/topic/1244051-help-please/#findComment-13998815
I'm connected to the videocard and my mobo has that same graphic. I've tried with a monitor and a tv. The only thing I didn't tried was the displayports because I do not have that cables yet. I can go and buy one but I am not sure that will fix it.
https://linustechtips.com/topic/1244051-help-please/#findComment-13998820
45 minutes ago, Comixbooks said:
See if you can toggle the settings on the monitor using the buttons for HDMI or DP input assuming if it works. Could be a memory problem you can take out all the memory but one stick see if that helps.
Yes, I tried that but still not work :(
https://linustechtips.com/topic/1244051-help-please/#findComment-13998823
-= Moved to Troubleshooting =-
 CHRISTIAN MEMBER
https://linustechtips.com/topic/1244051-help-please/#findComment-14000887
Have you tried a different GPU? Different hdmi cord?
System Specs
  • CPU
    AMD Ryzen 7 5800X
  • Motherboard
    Gigabyte AMD X570 Auros Master
  • RAM
    G.Skill Ripjaws 32 GBs
  • GPU
    Red Devil RX 5700XT
  • Case
    Corsair 570X
  • Storage
    Samsung SSD 860 QVO 2TB - HDD Seagate B arracuda 1TB - External Seagate HDD 8TB
  • PSU
    G.Skill RipJaws 1250 Watts
  • Keyboard
    Corsair Gaming Keyboard K55
  • Mouse
    Razer Naga Trinity
  • Operating System
    Windows 10
https://linustechtips.com/topic/1244051-help-please/#findComment-14001048
