Does Keycaps Makes Keyboard Sound Different
MESSERR
im new to mechanical keyboard stuff, and i just got my first mechanical keyboard (ajazz ak510) and i want to replace the keycaps with the blank one so it will look cleaner. So my biggest question is does keycaps makes keyboard sound different?
-> Moved to Peripherals
Please post to correct subforum
No if the keyboard is well made. The keycaps should never hit bottom plate to make sound.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
No the keycaps wont make it sound different.
It's the switch that make sound.
The keycap will make it sound different to a certain extend.  The material, thickness and profile will influence the sound.  Go around 10:38 ... that's interesting ... also go to the end, the typing demo is there ... and then watch the second video ...
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
Yeah they will change the sound. How much they change the sound completely depends on the material, thickness, type (doubleshot, dyesub, etc), profile, etc.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
It will change the sound but not more impactful than the rest of the components. There are many factors to consider such as plate, switches, and indeed the keycaps.
As written above, the thickness, profile, and material matter the most, for example OEM-profile dye-sub PBT keycaps will sound remarkably different to Cherry-profile ABS keycaps.
I own multiple keycap sets and no two of them sound the same, as they are all different heights, profiles, materials, lettering methods etc. so you will have to be aware that keycaps change the sound signature of your keyboard if you opt for another set that is not the same material and height.
While the switch can be a factor of how a keyboard sounds, in this example with the keycaps, the keycaps do in fact alter the sound of the keyboard.
Take it from someone who owns a fair share of keyswitches and uses a single set of keycaps to ensure uniformity in the actuation, feel, and indeed sound of the switches I test.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
Wrong. The caps WILL absoultly make it sound different. As will the switch, and the plate, and case, and lube in side the switch, and any foam inside the case.
