Hello.
I wanna build my own pc I picked all the parts that I want but before I buy I wanna make sure there are no problems. So I thought I'll post it here where people with more experience then me can help me.
The build:
https://nl.pcpartpicker.com/list/ksvr3t
If you can check for me if the parts are compatible and don't bottle neck something.
And I try to look for myself but the case am gonna buy comes with 4 fans and I have a cpu fan so I need 5 fan headers but I couldn't find information about how much my motherboard has.
I really appreciate if you can check it for me and thanks in advance.
Have a nice day.
https://linustechtips.com/topic/1242810-pc-problems/
30 minutes ago, boggy77 said:
the r5 3600 is better than the r7 2700x in almost every task, especially gaming, and is cheaper.
nvidia is launching the 3000 series, it's not sensible to spend 400+ on the 2060 super.
So if I replace the 2060 with a 3070 I would get better performances but doesn't something bottle neck the 3070 then?
https://linustechtips.com/topic/1242810-pc-problems/#findComment-13989609
