Guys.. MIT have been studying on the Alternative to Li-ion/-polymer Batteries. Graphene will be the Conductor between the Anode & Cathode, as per I got the info.
It's hoped to have More Battery life, Faster charging of more than 100W!!
When are expecting the Soild State Batteries on Mobile phone ? Laptops ? & maybe in Automobiles ?
Surely, Elon sir is goin to use that on Tesla models. Lol
https://linustechtips.com/topic/1242728-solid-state-battery/
Graphene batteries are nothing new. little bigger than a lipo for the same energy density as well, would be good for building/houses to replace off grid led acid bats
Silent build - You know your pc is too loud when the deaf complain. Windows 98 gaming build, smells like beige
https://linustechtips.com/topic/1242728-solid-state-battery/#findComment-13988810
This is nothing more than preliminary research, they haven't even demonstrated commercial viability yet! This is the same thing as with all the thousand other battery-related research out there, ie. nothing to get excited about, let alone expecting this research to actually yield any useable products until commercial viability has been demonstrated.
https://linustechtips.com/topic/1242728-solid-state-battery/#findComment-13988813
There's a ton of wonderful battery research out there, absolutely mind boggling tech, graphene battery is nowhere near.
Nothing to be excited about unless they are on it's way to the factory.
Li-Po really needs a successor, a new charging technique is to break the battery into separate compartments and charge them individually like it did on the new lenovo legion 5000mah phone. 50% in 10 minutes, full charge in 30min.
https://linustechtips.com/topic/1242728-solid-state-battery/#findComment-13988859
Thanks for the Valuableinfo. Appreciate it !
https://linustechtips.com/topic/1242728-solid-state-battery/#findComment-13994750
Its good, 2 Batteries.. Seperate chargers for them.. Faster the Charging ! But not every Mobile Brand has used this exept Lenovo & Black Shark :)
https://linustechtips.com/topic/1242728-solid-state-battery/#findComment-13994753
SSB are the future anyway in terms of batteries. Lithium ion is not sustainable
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1242728-solid-state-battery/#findComment-13995034
Solid state contains many types I guess, but every next weekend you will another GROUND BREAKING!!!1!!1! battery tech. Last is the magic that transform nuclear waste to energy that lasts for 10.000 years without charge. Don't put your money to any of them yet.
Samsung also does some realistic research about then and that is what you will most probably see in use on the upcoming years.
Graphene have been used to power banks as the guys mentioned above
https://linustechtips.com/topic/1242728-solid-state-battery/#findComment-13997786
5-10 years I'd imagine.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1242728-solid-state-battery/#findComment-13998153
