Hey there.
I bought the 3700x about a month ago, and I already dislike it.
I am not sure how this thing work and stuff, but teh issues I have, which I don't like.
1. I decided to try play Apex,  for the first 3-5 minutes, since the run, it working so slow, it stuttering so bad, i have less then 40fps.
after few minutes, it would start working properly, and the worst part, I do not see that the CPU under stress or the GPU.
2. While playing games, of any kind, but mostly CS Go , while watching movies on second monitor, the second monitor would statter.
I already updadtes MB , for latest BIOS and stuff, as well as for CPU.
So I would like to know, your thougths about it, as well as I am planing to switching from AMD back to Intel, If I get the chance to sell this  build.
I will be buying the 10700k .
YOur thought, go
Thanks. XD
CPU - AMD 5800XMotherboard - ROG STRIX B550-E GAMING , Memory  - G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 ,
GPU - NVIDIA GeForce RTX 3080 Ti MSI SUPRIM X 12G,  Case - 4000D AIRFLOW Tempered Glass Mid - Tower ATX Case - Black ,
Storage - Samsung 970 EvoPlus 500GB - Samsung 870 EVO 1TB + 6TB HDD,
PSU - Corsair HX1000 , Display -  ASUS TUF Gaming VG27A 165HZ + Dell 24 UltraSharp Monitor , Cooling - Noctua NH-D15 Black ,
Keyboard - Razer Stalker , Mouse - Logitec G502 Wireless , Operating System - Win 10 Pro ,
Sound - Logitech Z906 5.1 THX Surround Sound Speaker System
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/
I have the 3700X myself and don't have any issues that you have. I don't play Apex but your issue with CSGO is not there for me. Check hardwaremonitor while you have the stuttering, maybe some cores are failing to wake up from sleep mode. In this case deactivate any fast-boot options in Windows and BIOS.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13984837
used to happen to me too, except i have the 2700x.
however it doesn't happen anymore since i changed out my ssd's and got an m.2 as most of the time it was when a grenade exploded or during loading screens.
which is wierd when it's partnered up with a 2080
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13984841
Why are you so sure it is a CPU issue? What are the rest of your specs?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13984852
https://www.asus.com/Motherboards/ROG-STRIX-B550-E-GAMING/
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800) Intel XMP 2.0 Desktop Memory Model .
samsung 970 plus m.2/
samsung 860 evo 500gb
corsair 750 watt psu
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13984932
why I would think different?
I used 4790k and never anything like this, my first time trying Amd, and this happend
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13985171
and is the boot drive the same? have you done a fresh windows install or not?
also what gpu? and temps? and do you have xmp/docp enabled?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13985178
I'd advise reinstalling the OS. Perhaps my problem is different but I had the same stuttering issues even when I'm not playing games on my 2700X when I first built it. I reinstalled the OS and the problem is gone, never to be seen again.
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13985284
Well, I solved the issue.
It is unfortunate that I was suggested to reinstall my OS, as well as I was asked If when switched to a new CPU and MB, if I had a fresh installation.
ANy way, the issue was in the SOnic Studio 3.
When you separate the sound for the game and the movie, between headphones and speakers, you get this issue.
Not in every game, and in each case, but it does happens.
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13994657
Uuh, can you elaborate?
Is the app a CPU power hog or something?
Main Rig :
Laptop :
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13994663
Nop, it has nothing to do with the cpu, it is just creat some sort of issue. I am not a profesional to find properly the issue, but I know for sure it is the Sonic studio. I tested it.
https://linustechtips.com/topic/1242222-3700x-stuttering-issue/#findComment-13997840
