Hey there
I just bought a new Corsair Force MP510 960 Gb NVMe drive. The read speed is listed well above 3000 MB/s. I have benchmarked it several times with CrystalDiskMark, but I am only getting speeds around 800 MB/s. I am currently running it on a MSI Z97s SLI Krait Edition. In theory, this MB supports PCIe 2.0 for the M.2 drive, which should be enough. I don't know if there is some limitation that I am not aware of, or if I may have configured something incorrectly. Is it perhaps not possible to run it in the normal 2x mode that is listed on the website for my MB (https://www.msi.com/Motherboard/Z97S-SLI-Krait-Edition/Specification)?
Before you call me out for buying something that would obviously be bottlenecked by my current system, be aware that I bought this in anticipation of upgrading this fall to a 4th gen Ryzen system (there was a good sale on this SSD).
Appreciate it
https://linustechtips.com/topic/1239949-problems-with-new-nvme-drive/
But do you actually need an NVME Drive? Most people STILL dont need one, as they dont offer much unless you are actually using a program that can utilize it.
Make sure your BIOS is properly set up to run it in the proper mode.
Two lane PCIe Gen 2 is about 1 GB/s. You're hitting that limit.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
THats your problem. That speed you got is about the max those board can handle. THe drives are made for pcie gen 3 x4, or about 4gB/s
Your system supports pcie gen 2 x2, or about 1gB/s, and those speeds seem right.
Each lane of gen 3 is 1GB/s (Roughly)
Each lane of gen 2 is 500Mb/s (Roughly)
2 lanes of 500MB/s means a theoretical maximum speed of 1GB/s -- Getting 80% of your theoretical speed isn't bad at all.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Just now, Dewam said:
I was under the impression it was 1 GibeBYTE and not 1 GigaBIT?
It is one gigabyte per second on a pcie gen 2 x2 link, so those speeds are right. Your read speeds are just a bit under one gigabyte per sec
I read some more, so it seems like you guys are correct. PCIe 2.0 2x is limited to 1000 Megabit/s, and I am hitting the correct speeds.
However, I can't help but correct that you are using the term Gigabyte in place of Gigabit. My speeds are a bit under under 1 Gigabit/s, not 1 Gigabyte/s. My speeds translate to only 10% of 1 Gb/s.
You're the one with the wrong units.
PCIe 2.0 x2 is 1000 megabytes/s.
Your test is 0.8 gigabytes/s. (Gibibytes technically, but gibibytes are dumb. Point is everything is in bytes.)
¯\_(ツ)_/¯
Desktop:
Laptop:
