Big vs small heatshink plate.... Artic esports 34 duo ???
Solved by PWforPower,
On 8/15/2020 at 10:03 PM, PWforPower said:I've seen noctua nh d15(I think best air cooler) have big plate with two radiators and 24 heatpipes, while fuklng Artic esports 34 duo have tiny plate with 8 heatshinks and 5 times cheaper than noctua and less space.
I would buy artic, but I dont know if its good how they say. I would fit it on i7 3930k oc 4.4ghz or 4.2 ?
https://www.arctic.ac/en/Freezer-34-eSports-DUO/ACFRE00074A
Fuk both, I've bought PHANTEKS PH-TC14PE red
