Help with Korean 1440p Monitor
Viroth
I donit really know much about monitor technologies. But I'm looking to buy a 1440p one from eBay, pref a gloss. Does anyone have any hands on experience with these kind of monitors. I've not used a monitor brand other then Acer and Dell. How do these Korean brands compare? I have put some links to some I have seen that I may consider. Any of these shine out as obvious choice?
http://www.ebay.co.uk/itm/Glossy-New-27-MOEX-M27QSM-2560x1440-QHD-SAMSUNG-PLS-Panel-Computer-Monitor-/131098942757?pt=UK_Computing_ComputerComponents_Monitors&hash=item1e861b1d25
http://www.ebay.co.uk/itm/CROSSOVER-BLACK-TUNE-2735AMG-IPS-LED-27-LG-H-IPS-2560X1440-27inch-PC-MONITOR-/111099925819?pt=UK_Computing_ComputerComponents_Monitors&hash=item19de12553b
http://www.ebay.co.uk/itm/Perfect-Pixel-X-STAR-DP2710-LED-27-QHD-2560x1440-Samsung-PLS-Panel-Matt-/221239034169?pt=UK_Computing_ComputerComponents_Monitors&hash=item3382dfc139
Also, how would the compatibility be with UK's 240V Main power?
Any help would be appreciated.
Intel i5 4670k @4.5 | 16GB Patiot Viper Xtreme | Corsair H100i | MSI Z87 GD65 | Crossfire x2 Asus 7950 Direct CUII
250GB OCZ SSD | LG Bluray RW Drive | 750Watt PSU | Corsair 450D | Corsair K50 | Corsair M40
I'd get the pixel perfect one.
It'll be fine with the right adapter.
The Korean ones are bare bones. No stand adjustment, very minimal OSD, no adjustments in the OSD, the panels are rejects from the other brands.
There will be issues, that's why they're so cheap.
People have had luck, others have been burned. You might be lucky.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I got two of them.
1) Yamakasi Q270 2B OC edition, 400$, pixel perfect: no dead pixels till today, no backlight bleeding, overall perfect.
2) X-Star DP2710 (the third link you posted), pixel perfect, 230$ back then: no dead pixels till today, some backlight bleading in the corners, overall alright.
I'd recommend the X-Star, but only because I have positive experience with it. Dont know about the other 'brands'. Just make sure to always get the pixel perfect version, because they actually are.
btw both my monitors came with a universal 110-240V power brick, I just had to pick a standard power cord and everything worked fine.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
According to the owners club, the Pixel perfect version has shown no evidence of being less likely to have dead pixels than the normal version. If people do have any dead pixels, very rarely will there be more than 3-4.
Minor backlight bleeding is pretty much constant with these monitors but that is hardly noticeable and doesn't matter. Many monitors bought have risk of dead pixels anyways. And just because the monitor was rejected, doesn't mean that you will have issues. Most Korean monitors bought have no dead pixels and minor back light bleeding is present in most brand monitors as well. Nothing really to be concerned about, as long as you are fine with the sub par build quality.
These korean monitors are a really good deal, colors and quality will look amazing. My recommendation is that you get non pixel perfect Xstar.
Thanks guys for the response and advice :D I'll be picking up one X-Star pixel perfect :)
I literally just got my non pixel perfect x star like 20 minutes ago and I have only good news to report. It looks amazing and has no dead pixels. Hardly any backlight bleeding is visible and the size and colors are crazy. Also overclocks well.
If you get one you won't regret it
Does it have a vesa mount?
yes it does. I might buy a wall mount later
I'd be careful about this as I have seen other saying that the holes are not tapped properly etc so a vesa mount may not fit correctly.
Bought a QNIX QX2710 (Matte PerfectPixel) last week and I love it, AU$350 delivered in 4 days - can't complain.
Whacked a SilverStone LCD Arm onto it and its golden on my desk. Didn't even have to take the glass off (yes my desk has a glass covering over wooden top :/).
