help with ram
Go to solution Solved by RONOTHAN##,
3 minutes ago, Dedayog said:
To note, HU found that the 7800X3D isn't impacted by CL as much as other CPUs, so if folks can find CL32 cheaper they should feel fine about getting it.
Unless other testing has changed that opinion?
It doesn't even make much of a difference on the non-X3D chips as CL30 and CL32 are such close values. The only reason I wouldn't recommend a CL36 kit as well if it was cheap is that you might end up with a CL36-44-44 kit and end up with potential compatibility issues.
5 minutes ago, GHOSTX1 said:
also i need wifi and bluetooth to be in my mb
I mean, if this is your only requirement, a B650M-HDV/M.2 and a ~$20 WiFi adapter like the Intel AX210 would be plenty and save you ~$50 on the motherboard.
8 minutes ago, GHOSTX1 said:
also i was looking at this memory, https://amzn.eu/d/9XMwyob
That's a fine kit, if you want RGB that's the kit I would recommend.
hello, fellow forum users
i need some help choosing ddr5 memory for a ryzen 7 7800x3d
what is the difference between cl ratings? aand what speed should i go for?
i am going with 32gb ram, with the MSI MAG B650 TOMAHAWK WIFI mb (if thats relevant)
also any motherboard reccomendations? (if the one ive picked isnt ideal)
https://linustechtips.com/topic/1572376-help-with-ram/
It's one of the memory timings measured in clock cycles, lower is better for a given frequency.
The answer is pretty much always 6000 CL30 or CL32. Speeds higher than 6000MT/s don't work ideally out of the box on AM5, and CL30 and CL32 are the lowest latency kits you can find on DDR5. Plus, 6000 CL30/32 is usually some of the cheapest RAM you can find, so its not like you save much money by going for a slower kit anyway.
The one you picked is fine, though there are likely better options available. Where are you shopping for motherboards, how much were you looking to spend, and what features do you need?
https://linustechtips.com/topic/1572376-help-with-ram/#findComment-16427602
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($339.99 @ Amazon)
Motherboard: *Gigabyte B650M AORUS ELITE AX Micro ATX AM5 Motherboard  ($141.00 @ Amazon)
Memory: *Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($94.97 @ Amazon)
Total: $575.96
Generated by PCPartPicker 2024-06-02 21:47 EDT-0400
current PC:
PC configs I used before:
https://linustechtips.com/topic/1572376-help-with-ram/#findComment-16427603
I am using an Asus X670E-E motherboard with 64GB Corsair Dominator Platinum RGB ram without any problems at all.  The ram is CMT64GX5M2B6000C40.  So it isn't 30 or 32 but it works just fine.  This will be my final upgrade since I will be 70 years old in a few months so I went the extra mile on some of the parts.
Take care and good luck.
https://linustechtips.com/topic/1572376-help-with-ram/#findComment-16427612
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1572376-help-with-ram/#findComment-16427613
should have probably mentioned im in the uk, also i need wifi and bluetooth to be in my mb
https://linustechtips.com/topic/1572376-help-with-ram/#findComment-16427614
https://linustechtips.com/topic/1572376-help-with-ram/#findComment-16427618
