Help with PC build for programming
Go to solution Solved by coolbean28,
I created a quick list, you can change it how you like but this would be a great build for a programmer like you. https://pcpartpicker.com/list/cmByn6. You can find the Windows key at Keysfan.com.
Budget (including currency): 1000 - 1200 USD
Country: USA
Games, programs or workloads that it will be used for: Top priority will be for programming. There will be some light gaming, but nothing intensive. I will mainly play csgo or valorant. The most intensive game I have is helldivers 2, which I don't mind playing at lower settings.
Other details: I do only have one requirement for parts. I really want the build to be in a Fractal Design North ATX Mid Tower Case. I have two monitors and all the peripherals that I already need. Also, I don't really care about RGB, so if some money could be saved or put elsewhere, I wouldn't mind. I am very new to PC building, so let me know if you need more info. ✌️
https://linustechtips.com/topic/1572378-help-with-pc-build-for-programming/
