Search In
  • More options...
Find results that contain...
Find results in...
Setting up Raid 5 and Sharing drive between PCs
Go to solution Solved by Electronics Wizardy,
1. Yea storage spaces is the best way to go on windows 10.
2. It will just show up when you move it to anouther compatabile system(so windows 10)
3. You can just add more drives to the pool and then expand the virtual disk.
3a. Storage spaces isn't a traditional raid so you can mix sizes. THis depeds on the exact config, but by defualt its 1 parity for every 2 data chucks, so with 2+2+3+1 you should get about 2.3 tb usable
4. Under folder properties, then sharing you can share the folder for others to use
i have a 2TB toshiba drive, 2TB WD Blue, and 3TB WD green, i would like to run raid 5 on them, is it possible and recommended?
if it's possible:
1) is this the right way to do it?
2) how do i rebuild the array when i reinstall my OS?
3) how do i add more drives to the array? same step as 2)?
  3a) i think it's possible to add smaller or larger capacity drive to the array? just that the largest disk might have wasted space (ie 2+2+3+1 ~= 5TB, 2+2+3+3 ~= 7TB?)
4) how do i make it so the array shows up on my other PC on the network as a hard disk in file explorer?
Things I need help with: *new* What can Facebook do to me? Privacy Inquiries
I hate Intel's pricing, Ryzen's weird quirks, Nvidia's pricing, and Radeon GPUs in general
Products I like:
Sony Xperia Z1 / Z2 / 10 ii, Asus Strix 970 / 1070, Samsung SSD, WD HDD, Corsair PSUs (AX, RM, CX(grey)), GeForce GPU, NZXT N450/S340, be quiet! Coolers, G.Skill Trident RAM, Logitech M525, Logitech G440, Razer Deathadder Elite
Products I hate:
Xperia Z3, XiaoMi 5c, Radeon GPUs, Razer Audio Products, any bloatwares
Companies I absolutely adore: (and hope it stays that way)
be quiet! - sent me AM4 mounting for my DRP3 even though it's way past the timeframe stated, no questions asked
Corsair - very good RMA experience, absolutely recommend
Companies I hate:
Nvidia, Intel, Apple, TMT (Thundermatch, a retailer)
Personal Blacklisted Companies:
Acer: shit tier quality products, shit tier customer service thus far, they "tried" to solve my issue but they arent really doing anything but delaying and delaying. (on-going case since July)
Gigabyte: horrible customer service (gigabyte had literally 0 customer service, asked me to go to retailer with NO WAY to email them about a question) but at least they fixed my shit in ONE MONTH (would probably take me 1 hour to fix if they let me email them)
XiaoMi Phones: built like a tank but the software is buggy as all hell
Seagate HDD: had too many dead seagate drives
Kingston SSD: 300V controller swap thingy
Razer (except their mouse)
Remember, just because I had good/bad experiences with these companies/product, doesn't mean you will have similar experiences too. I would still recommend these products if they made sense for your needs, but I'll add a disclaimer of my experience if it's relevant. Feel free to DM me asking why they are where they are.
1. No. Don't use Windows RAID. It's not proper raid. Buy a RAID card when then exposes the array, fully done and protected, to the system.
2. 1. prevents this. You don't.
3. Depends on the RAID card. You may need to reformat the entire RAID array
3a. Yes, the smaller disks will have wasted space but you want spares so you can have the 3tb WD green as a spare and the 2tb Toshiba and 2tb WD blue in RAID 1 with the WD green as a hot spare, you can't do much with 3 drives/
4. Just make it a network share.
@BlueScope819 so I can see your post
#MuricaParrotGang
My name is Legion 'Murica Parrot Gang, for we are many.
If a design is taking too long, the design is wrong, and therefore, the design must be modified to accelerate progress. -Elon
Mentioned in 8/5/2020 TechLinked
storage spaces is a pretty good software raid setup, think of it like zfs. Its better in features than most raid cards.
Most raid cards allow online expansion of raid arrays.
wha? how about 2+2+3? i need about 4TB of storage for now
can it prevent data loss if one of my drive fail? that's all im asking for
i need 4TB of storage space in a single array with redundancy, thats why im looking at raid 5
i'll explore this right now, thanks!
edit: oh i forgot to mention, there are multiple people on the network and i only want to share between my own PC
Products I like:
Products I hate:
Companies I hate:
rip math, 2.3 is wrong
2+2+3 should give you 4tb usable, adding a 1tb drive will give you more space.
Yup it will do that.
One thing to note is storage spaces parity is known for slow write speeds(about 60mB/s). There are some tweaks, but its not great.
im cool with that, mostly archiving and more reading than writing
any approximation for 2+2+3+1 and 2+2+3+3?
1 minute ago, OIIOOIOI said:
Do you have a clean 10GB LAN between both PC
i have 1Gb link between my main desktop and router, as well as my secondary PC, it should be enough for what i do
3 minutes ago, OIIOOIOI said:
i would like both PC to stick on the windows platform if possible
Products I like:
Products I hate:
Companies I hate:
2+2+2+3, probably about 6tb
Want me to test this for you, I have the drives and a system, it might take a few hours though
no it's fine, as long as it's more than 4TB then im good
so i've been looking at this page and i allowed one of my test hard disk to be shared over the network
but when i key in the network path in file explorer, im prompted to key in credentials, which i dont think i have set any password on my desktop, so idk what to key in
also how to limit the share to only myself as i share my network with few people
Products I like:
Products I hate:
Companies I hate:
Timestamped for you.
#MuricaParrotGang
He is probably talking about the disk management raid, this is much different than storage spaces.
Also is linus really the best guy to be quoting for how to do storage correctly? There have been many video about non optimal storage setups he has done. I know many places are using stoage spaces without issues in big storage arrays.
Okay, sorry for taking the advice of the person that this forum is named after.
#MuricaParrotGang
like... what do i even key in? i didnt set any password to my desktop
Products I like:
Products I hate:
Companies I hate:
I mean the guy posted this
Not only did he not have backups(big non no)
Thats was a very bad config.
Set the password of the server pc, so the desktop.
You normally need a password to do it, or give access to everyone.
I don't disagree with you, please do forgive my skepticism.
#MuricaParrotGang
basically a windows login screen password?
sorry for sounding like a totally incompetent person but this is really not my cup of tea
Products I like:
Products I hate:
Companies I hate:
yea give it the username and password you login with.
after some PM-ing (because of credentials and stuffs) i got it working
now i just have to find time to move the data on the drives and setup the raid and i should be good to go
thanks @Electronics Wizardy very much for your help
again i apologise for sounding like a noob, but networking stuffs is really out of my hands
also thanks @BlueScope819 for the info too
Products I like:
Products I hate:
Companies I hate:
