Hi everyone!
So I recently bought my first pc. It has a ryzen 7 3700x and 16gb 3600mhz cl 18 tridentZ RGB ram. I am facing a problem when I play minecraft though - I'm getting only about 130 fps at 12 chunks. I have the capacity to run the game at much more fps but why can't I?
https://linustechtips.com/topic/1230762-minecraft-issue/
Can you list the full system specs so people can better advise.
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1230762-minecraft-issue/#findComment-13892626
Simply put because Minecraft doesn't use a good render API. Afaik it's running with openGL, which is badly optimized. If it would have a good Vulkan or DirectX11/12 implementation, it will likely run much smoother. But i doubt that will ever happen, because this would require fundamental reprogramming of the game.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
https://linustechtips.com/topic/1230762-minecraft-issue/#findComment-13892639
Did you changed the allocated memory?
Go under profiles, look for the profile you want to play on eg. 1.16.1, press more options, find the JVM arguments and change -Xmx1G to like -Xmx8G ( 1 to 8GB Ram)
EDIT: my specs: 2600x , 16gb 3000mhz ram, GTX1060 - im getting like 6-800fps on unlimited fps setting
https://linustechtips.com/topic/1230762-minecraft-issue/#findComment-13892671
This could help too, but i run into similar limits with minecraft like op is. Also running 3700X and 16GB of 3600MHz cl16 RAM and a 1080Ti. Also if you don't already use it, install optifine. My limit is 16 chunks while keeping my monitors 120Hz satiated.
https://linustechtips.com/topic/1230762-minecraft-issue/#findComment-13892684
Just now, Stahlmann98 said:
This could help too, but i run into similar limits with minecraft like op is. Also running 3700X and 16GB of 1600MH cl16 RAM and a 1080Ti. Also if you don't already use it, install optifine. My limit is 16 chunks while keeping my monitors 120Hz satiated.
optifine is a very good idea.
If you´re playing older versions like 1.12 and below, check out labymod or badlion client, gives you better customization regarding video settings
https://linustechtips.com/topic/1230762-minecraft-issue/#findComment-13892687
9 minutes ago, gloop said:
Bad optimization of the actual engine.
As @Stahlmann98 said, don’t expect a redesign because of how long it would physically take to reprogram all of Minecraft.
For some reason turning off game mode from windows settings fixed it
https://linustechtips.com/topic/1230762-minecraft-issue/#findComment-13892704
Haha what even is "game" mode? Never heard of that for windows. Good to hear it actually decreases your performance :D
https://linustechtips.com/topic/1230762-minecraft-issue/#findComment-13892708
Yeah that was already on, I didn't even do it myself. I heard somewhere that it decreases performance so I tried it out and sure enough, it worked!
https://linustechtips.com/topic/1230762-minecraft-issue/#findComment-13892740
