Is there a difference?
Go to solution Solved by DarkAavenger777,
23 minutes ago, Spudwell06 said:
Is there a difference between a video card and a graphics card?
same thing
no. They are just diffrent terms for the same thing.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1230346-is-there-a-difference/#findComment-13889044
No, it's the same thing.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1230346-is-there-a-difference/#findComment-13889045
4 minutes ago, nE0n1nja said:
Graphics Processing Unit = Video Graphics Adapter (Array). Means all of those terms and abbreviations are the same thing.
I think VGA is referring to standard of analogue signal:
Quote
Today, the VGA analog interface is used for high-definition video, including resolutions of 1080p and higher.
https://en.wikipedia.org/wiki/Video_Graphics_Array
Pax vobiscum
https://linustechtips.com/topic/1230346-is-there-a-difference/#findComment-13889190
Yeah but I've also seen the term VGA being used for Video Graphics Adapter, or somewhere as SVGA or Super Video Graphics Adapter. For example googling the term "best vga" gives you results for the best graphics cards.
https://linustechtips.com/topic/1230346-is-there-a-difference/#findComment-13889255
12 minutes ago, nE0n1nja said:
"best vga"
Most of the google searches refer to cables...
I know it's a matter of interpretation, but still VGA means something else that graphics processing unit.
But let's not start an argument. "VGA card" is an anachronism...
Pax vobiscum
https://linustechtips.com/topic/1230346-is-there-a-difference/#findComment-13889267
