My pc currently only have one fan in the case, its the stock one from phanteks, my cpu is being cooled by the stock cooler as well. My cpu runs at a stable 69 degrees (nice) and my gpu is hovering around the 70s, but if i were to use it long enough, it can reach the 85 degrees but it rarely does. My case have 3 140mm fan slots empty. But there is one small problem though, my case gets really hot if i used it for a long period of time doing heavy tasks.
So my questions are:
1. Will case fans solve the hot case issue
2. If it will, will i need good quality ones
3. Can you give me a suggestion on a fan that cost around 10$/pcs (I prefer not having rgb)
-Main PC-
CPU Ryzen 3 3100 | | Motherboard ASRock B450M-HDV R4.0 | | GPU PowerColor Red Dragon RX 580 | |RAM 16GB Patriot Viper Steel 3000MHz | | PSU Corsair CX550 80+ Bronze | | SSD Kingston A400 240GB | | HDD Seagate Barracuda 1TB 7200 RPM  | |Case Phanteks P300
-Laptop-
HP Elite 820 G4
Intel I5-7200U
Intel HD 620
8GB DDR4
500GB SSD
https://linustechtips.com/topic/1229934-do-i-really-need-case-fans/
Do you need case fans? No. Will they improve your temps? Very probably. Just remember, intakes are filtered
This is a pack of 5 for 25$. They aren't gonna be nice, but they'll shift air
the p300 only has 1 fan for exhaust, adding 1 extra fan for intake should help getting more air inside the case.
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
Probably yes, but a hot casing doesn't matter as long as your components don't run hot
No you don't, unless you want them to be quiet or run at low rpm, which noctua fans do very well
To find out if your airflow is causing heating issue, open up your side panel
If temps on CPU and GPU drop more than 5-ish, then it's insufficient airflow, around 5c ish drop is normal
-sigh- feeling like I'm being too negative lately
Just get 2 more Arctic P12 PWM's and put them in front. This will solve any issue you'll have in terms of temps. Depending on where you are you can get them between 5$ and 10$ each. They're not much, but they get the job done. If you want something better the Arctic Bionix F120 are a very good choice, as they move more air as a case fan.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
You linked the arctic f8's those are 80mm fans what op will probably need is the f12's which are the 120mm ones. They are actually pretty darn nice fans for the little they cost.
Thank you for all the responds guys
-Main PC-
-Laptop-
HP Elite 820 G4
Intel I5-7200U
Intel HD 620
8GB DDR4
500GB SSD
