No Sound On Radeon R7 240 GPU
19 minutes ago, BioLashout said:Okay so I come from the old Intel days where the only thing you needed was Intel. I purchased a PC in 2008 and upgraded in 2011 and this is the 1st time I upgraded to AMD.
The reason I got the R7 240 was because I was on a budget and my work in the Graphics & Web Field required me to use a GPU.
I hardly game and when I do its just the odd Craft the World! I mainly use my PC to run Adobe Suite CorelDraw and watch movies & Series.
"stupid question to follow!!!"
Will the integrated GPU as you stated run my software?
The Integrated Graphics (iGPU) within your Ryzen 3400G Processor is quite powerful compared to the R7-240.
It is just like any other graphics card...just built into your CPU.
Did you check your playback device options within Windows?
Is the audio option through the R7-240 disabled?
Under 'Manage sound devices'
Under 'Sound' in Control Panel
