Hello,
I currently have a Ryzen 3700+ CPU And an EVGA KO Ultra GPU and when I am gaming, the case gets pretty hot, but everything works fine. The temperature gets between 60-70c when gaming and 40-45c when idle. I have the Wraith Prism cooler and two case fans, the side panel as intake and the back as outtake. I have an Antec A400 fan that lowers the temp when gaming by 10c, but I can’t fit the side panel fan and I have to install it outside the case..
When I’m gaming I game for about 3 hours at a time, will the case getting too hot will damage the GPU And CPU? Sorry for the long post.
Any help appreciated.
MSI B550M PRO-VDH WIFI
Amd Ryzen 5800x CPU
2 X 16 GB Team Group T-Force Delta DDR4 Memory
EVGA RTX 2060 KO Ultra Video Card
Sound Blaster Audigy FX Pcie
WD Black 8 TB SATA 600 HDD
Crucial P1 2TB Nvme SSD
Seagate Desktop 8TB USB 3.0 Hard disk
LG Blue Ray Drive
Bose 2 Companion Series 3 Speakers
LG 27GL83A-B 27 Inch Ultragear Monitor
Azza PSAZ-650W PSW
APC Back-UPS BN650M1 360W Battery Backup
Logitech MK550 Mouse and Keyboard Combo
Bose Quiet Confort 35 II Headset
Antec A400 cpu cooler
Antec 120 mm blue Case fan
Agiler AGI-C006B case
Razer Wolverine Xbox One Controller
PS5 Game Controller
Samsung T5 2TB External SSD
https://linustechtips.com/topic/1225865-cpu-and-gpu-temperature/
No for the most part.
Temps are fine as a whole. Where did you get temps reading for your case anyways?
Phone: Pixel 3a (Purple-ish).
Build Log:
I used the program HW Monitor.
Amd Ryzen 5800x CPU
LG Blue Ray Drive
Azza PSAZ-650W PSW
PS5 Game Controller
That doesn't report case temps. You can't record case temps with software.
Don't use hwmonitor. Use hwinfo64. As hwmonitor is inaccurate most of the times.
But temps are fine.
Build Log:
I have HWINFO on my computer, will run it when I get home and post the updated temperatures.
 Thanks.
Amd Ryzen 5800x CPU
LG Blue Ray Drive
Azza PSAZ-650W PSW
PS5 Game Controller
17 minutes ago, giovanni1972 said:
Hello,
Considering the horrid airflow, your temperature readings are good. Enjoy your hardware
I’m assuming you used your hand to get a temperature for the case? If so, just know that if it’s hot to people doesn’t matter at all. Hardware can get way past what will burn your skin and still be in a safe temp range.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
Hello,
After a couple of hours gaming, using HWINFO, the cpu die temperature minumum temperature is 43.2C and the maximum is 75.9C. I don't expect much from my computer case since is generic basically, just making sure everything doe not melt down. The other thing I have to obviously upgrade is the monitor, even when V-synch on there is tearing.
Thanks all for the replies.
Amd Ryzen 5800x CPU
LG Blue Ray Drive
Azza PSAZ-650W PSW
PS5 Game Controller
