4 minutes ago, AshSenpai said:
hello guys this is my first time posting on this site:P ,, I was wondering if i can run my old cooler master v6 GT on the new i7 10700k ?? note that it is on my i7 3770k and its time for upgrade lol
you shoudl go with AMD right now. get 3700x. almost as good as 10700k but the cpu, cooling and motherboard will cost you much less.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1221136-10th-gen-cooling/#findComment-13813424
Welcome to the forum!
Yes, will work. You just need some new thermal paste.
The 10700K is an LGA 1200 CPU, while the 3770K is an LGA 1155 CPU. It has been confirmed LGA 115x coolers will work with LGA 1200. So you can just uninstall the cooler and take all the brackets and such and install it in the new CPU.
The thermal paste does need to be replaced, so just get a tube of paste (like Arctic MX-4) and you're fine.
https://linustechtips.com/topic/1221136-10th-gen-cooling/#findComment-13813427
Actually it's really not imo. If you can wait. Then wait for zen 3 and check what it has to offer.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1221136-10th-gen-cooling/#findComment-13813428
Either wait for Zen 3 or get a 3700X. The 10700K is just not worth it. It's not faster than a 3700X by more than 2-3%, it's hotter, more power hungry and needs a more expensive board and cooling.
https://linustechtips.com/topic/1221136-10th-gen-cooling/#findComment-13813451
thank you all for your great and fast replies ,, as for the thermal paste yes i will change it :P ,,
But for AMD I'm not sure if i will go with it because i feel like it will have some bios issues and some support issues for games and windows i want something reliable to game on after a loong day at work
https://linustechtips.com/topic/1221136-10th-gen-cooling/#findComment-13813619
Just now, AshSenpai said:
? or wait for zen 3 to be cheaper ??
Zen 3 is ryzen 4000. Not released yet.
Build Log:
https://linustechtips.com/topic/1221136-10th-gen-cooling/#findComment-13813989
sorry I'm not very good with AMD gen :P thank you and i will consider this but i was wondering is 3700x have any bios issues and is it reliable for gaming ?? and if you have an AMD CPU do you have any problems with it ?
I've never had an AMD product before so i was just wondering because i have couple of friends who had some issues with there AMD builds
again thank you bro @TofuHaroto
Edited by AshSenpai
Tag
https://linustechtips.com/topic/1221136-10th-gen-cooling/#findComment-13814001
No bios issues.
And it's "reliable"
Well that was probably the ram compatibility. Now it's a lot better.
But wait for zen 3 which should be around September.
Build Log:
https://linustechtips.com/topic/1221136-10th-gen-cooling/#findComment-13814018
