Specs?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1220466-cpu-upgrade-help/#findComment-13808030
Just now, Earnist_ said:
is b450i aorus pro WiFi so it should support the ryzen 3000 ,
With a bios update. It could've shipped with an older version.
What other specs do you have ?  If your trying to boot with no GPU then that wont work as the cpu doesn't have one.
Build Log:
https://linustechtips.com/topic/1220466-cpu-upgrade-help/#findComment-13808034
Gpu is inside , gtx 1650 super , 16gb of ram
https://linustechtips.com/topic/1220466-cpu-upgrade-help/#findComment-13808049
1 minute ago, Earnist_ said:
Reseat everything.
Clear the cmos. Try with one stick at a time. And I would still checking if the board shipped with the new bios.
Build Log:
https://linustechtips.com/topic/1220466-cpu-upgrade-help/#findComment-13808052
