2 monitors
Go to solution Solved by WereCat,
yes, you can
Hi
I would like to ask if my pc can run 2 montiors without getting into trouble.
My specs:
12Gb ram DDR 3
Nvidia GeForce 1060 6gb (Strix)
Amd Fx-6100
750W power supply
I was thinking aboit getting second montior but then i thought if this setup can even run 2 montiors.
Thanks to all that will replay
https://linustechtips.com/topic/1220085-2-monitors/
4 hours ago, BardiaMGTGC said:
maybe do an upgrade to ur cpu but ur gpu is fine
I can run triple monitors on my Thinkpad with a Skylake mobile i7 and Intel iGPU. He'll be fine.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1220085-2-monitors/#findComment-13805376
11 hours ago, DarkLegend said:
Hi
My specs:
12Gb ram DDR 3
Amd Fx-6100
750W power supply
That cpu is crapola! How do you not get MASSIVE bottlenecks?
https://linustechtips.com/topic/1220085-2-monitors/#findComment-13806060
You don't need almost any recourses to drive more than one monitor.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1220085-2-monitors/#findComment-13806213
