ultrawide monitor need help
maniey
Hello guys, im getting LG 34" 34WK650 UltraWide WFHD IPS LED HDR10 LED Monitor or other series might be cheaper, does any gpu support this monitor because this not for playing game just doing some business work..
so im getting cheapest and oldest card possible can u guys suggest any?
or can i just use intergrated graphic but which series?
help me and thanks alot
For Business Use, Integrated Graphics Is Perfectly Fine! As You Are Only Handling Just A Few Spreadsheets and Browser Tabs..
YES, I RUN RAID 1 OVER RAID 0
REMEBER TO QUOTE 😜
so its means..integrated graphic can do the wide angle resolution..?
  • 1 month later...
yes but would preffer you get a amd cpu for better igpu and better performance as intel cpu's really only shine in gaming and amd cpus are cheaper too
REMEBER TO QUOTE 😜
